Aim solo dl
neema
Fresno, CA
$700 and has the ability to log data from the OBD2 port as well as all the cool lap timing/predictive lap/acceleration data logging features from the regular SOLO.
http://optimummotorsports.com/SOLO.html
Anyone used one of these? There isn't much information on what channels work on 2011+ cars, but the more the better.
Beach Park, IL
I think that is what Fair has been running lately.
I went DL1 mostly because I could grow into it and it will be a very powerful tool for me. If I wasn't thinking bigger picture (shock velocity sensors, steering angle, yaw sensor, and maybe even brake pressure) I would have gone with the AIIM.
jayel579
North Jersey
Most of the guys I track with use it, many are BMWCCA club racers. The lap predictor is pretty neat I think. You can kinda watch your times drop or jump based on how you get through certain turns. My brother used it for his car, was even able to find out hard he put his car into the wall based off the data :/ good and bad data I guess...
neema
Fresno, CA
Care to share where you got it from? Also, are you using yours on a 05-10 car or 2011+? I'm interested to see what data channels work.
Beach Park, IL
I bought the DL1 on ebay...used....for $401. I was a little nervous, but it works fine. I got the OBD cable for it through SPS.
I can't say what will be available with the obd cable on the aim system. Just looking at track maps, speed gradients, and lap overlays along with lat and long acceleration numbers will keep you busy for HOURS. It's a lot to take in.
***It occurs to me that you may think we are talking about the same thing. I am running the Race technology DL1, not the AIM Solo.***
neema
Fresno, CA
ahh that clears things up. I understand the boatload of time that can be spent compiling data and merging with videos or diagrams. AIM has their own data analysis software that can be used. I think it's merging the data with video that will take time.
Here's a list of channels that the AIM Solo DL can receive from a Mustang (any copperhead?) ecu.
Taken from this website: http://www.jimmypribble.com/blog/2012/12/review-aim-solo-dl/
Appendix A – Data logged from Boss 302 ECU:
RPM
Speed
Pedal position sensor
Front left wheel speed
Front right wheel speed
Rear Left wheel speed
Rear right wheel speed
Traction control
Traction control alarm
Fuel level
Instantaneous fuel consumption (1)
Instantaneous fuel consumption (2)
Average fuel level
Fuel flow
Clutch switch
Traction Control Brake Event in progress
Engine Control Engine Event in progress
Brake switch
ABS Alarm
Axle ratio
Malfunction Indicator Light
Fail safe cooling mode
Gear
Tyre size
Stability Control Telltale NO/YES
Stability Control Telltale Text Message (code)
Electronic Stability Control event in progress
Torque
Brake Warning Telltale ON/OFF
Vehicle Yaw Rate
Vehicle lateral acceleration
Steering wheel angle
Tyre revolutions for mile
Beach Park, IL
RPM
Speed
The above should be useful.
I never even thought about steering wheel angle through the obd cable. I will have to find out if I can grab that.
What I would like to see added to that list is oil pressure, water temp, and Intake temp. Fuel trim and ignition curve would be useful as well.
neema
Fresno, CA
What you mentioned and oil temperature. I've felt some sort of soft power cut before I added an oil cooler and radiator, but I never physically saw anything light up on the dash. I wonder if "Fail safe cooling mode" would have perked up there.
I may bite the bullet but I'm still pouting over the $300 difference between the Solo DL and regular Solo.
The DL1 looks cool and totally unsuspective. Who would have thunk this little guy has GPS w/ datalogging?
