Airbag light - code B0028-13 help
KBGT500
Greenville, SC
At ignition on the airbag light comes on as normal goes off and then comes back on solid. It does not flash. Code scanner pulling B0028-13 Right Side Airbag Deployment Control - Circut Open.
Here is what I have completed/know so far:
- Car has never been in an accident
- Fuse is good.
- I have disconnected the battery for 48hours.
- Verified airbags replaced under recall
- I suspect seat position sensor. I do have power to that plug. I am not showing continuity on the sensor. Should it?
- In scouring the internet chasing this, I did find a PDF file with this code listed and it said to do a Pinpoint Test G, but I cannot find out what that is.
- Interesting tidbit: I just picked this car up from 2nd owner who acquired it in 2013. Got all the records. In that pile was a receipt from a small mechanic shop from 2014 noting the airbag light was on and this code. She said its been on since then and was told it was a seatbelt sensor and to not worry about it. So she didn't. She was 60 yo and never had anyone else in the car.
Any help or any other ideas?
Thanks,
Scott
JC SSP
FL
I have seen people bypass the air bag seat sensor. There are kits available.
