All Motor Chat - High Gearing, Light weight, Revin to the moon-
wbt
Bigger bore, shorter stroke will generally mean an engine that is suited for high RPM's. There are many benefits to running a larger bore/piston as mentioned. The Livernois unit may be similar to the 2013 5.0 N/A CJ engine in bore/piston size. Trying to confirm that....
ford20
White Plains,NY
I just reread the post that Rick@Livernois posted and he said that it was the same process for the Big Bore Blocks on the Cobra Jet so I am assuming that they mean the modular blocks and not the 428 Blocks that Ford Racing was selling for NHRA Eliminator Classes. Also I believe I remember a couple of people saying that this was the biggest you could bore the 5.0 to but I am seeing if I can find where I read it.
BMR Tech
Traction Vendor
Tampa, FL
I don't want to spread any false information, but I would bet that Livernois does the work for that CJ powerplant.
wbt
You bet they work very closely with Ford. I recall seeing the CJ intake being tested on one of their cars sometime last year. Fun stuff.
Confirmed that the 5.0 N/A CJ motor uses a 94mm bore, 3.70in. Same as the Livernois item linked however not the same internals.
BMR Tech
Traction Vendor
Tampa, FL
You might not want to stroke it if your going to turn high rpm's due to piston speeds being raised.
Most of the serious modular drag racers leave it at stock cubes or close to stock CID and just raise compression and boost.
Kinda....
The serious racers that make "big" power, utilize various combinations of parts/engine sizes.
The stroke thing....well, the 5.4 Modular Engine is the best platform to choose, when considering an N/A application. It has a 4.165 stroke IIRC, much more stroke than a 4.6. The fastest, most powerful N/A modular engines in the world utilize a larger stroke than the factory 3.54" stroke featured in the 4.6 engine.
The highest powered N/A Modular engines are typically always 5.4 based.
There are 1-2 guys that have been able to achieve mid 500's on a 4.6 based engine, both were 3.7" bore and 3.75 - 3.80 stroke. Both are also very questionable, as they were using "questionable" dynos. Even if the dyno read high, it doesn't compare to the 600+rwhp that has been made N/A, with a 5.4 through an automatic trans.
gil_t2
Love Nitro in the Morning
Northern Va
Way to much fuss is made over stroking a motor. Most people stick with factory spec's due to cost and availability of parts. Longer stroke works better with larger bore. As long as you keep the ratio close ( SQUARE )there aren't any problems. There are 100's of bore/stroke combinations on the streets. And most V8's are built on the same angle.
BMR Tech
Traction Vendor
Tampa, FL
Very True!
The 5.4 cannot go without merit though. It is the most common choice for Ford when building a powerhouse-specialty car.
gil_t2
Northern Va
Very True!
Agree, I have a big bore , stroked 5.4 , but could not finish and get it into the car after job layoff
Mike K
WANNA BE FAST
Richfield, MN
Now you guys start talking 5.4's when I'm debating a build. Bastards. Now I have more thinking to do. I want to do a high compression E85 NA build for an all around performer.
gil_t2
Northern Va
Been done , sitting in my shop :thumb2:. There is a lot of info posted here
Wicked97
Beltsville, MD
I have a
14-1 compression
RGR Ported Heads
Custom Cams
Aluminum Rods
Custom Crank
302 CI
Aluminum Block
Titanium Retainers
Custom Ferrea Valves
Aluminum Oil Pan
ALL tricked out stuff sitting in my show room right now...
Come Pick it up it made over 500 NA
You will be the real deal!!
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
That .24 of extra bore is very significant. It may seem small but there are 8 cylinders, could you picture increasing your exhaust tubing size by a quarter of an inch per cylinder?
Just look at the coyote, the heads are great but they would not be near as effective, hence the 100 hp increases from only 21 cubic inches, without the increase in bore size.
Sent from my HTC Desire HD A9191 using Tapatalk 2
Mike K
WANNA BE FAST
Richfield, MN
I'll have to look back in here and find the posts.
I have a
14-1 compression
RGR Ported Heads
Custom Cams
Aluminum Rods
Custom Crank
302 CI
Aluminum Block
Titanium Retainers
Aluminum Oil Pan
That would be nice but I'm going to try to do it on my own and on a budget. You don't want to give it to me for a wedding present do you? :roflmao:
ford20
White Plains,NY
I know right lol. I had one thing in mind but now I am like well hmmm maybe i can do a big bore stroker lol
I have a
14-1 compression
RGR Ported Heads
Custom Cams
Aluminum Rods
Custom Crank
302 CI
Aluminum Block
Titanium Retainers
Aluminum Oil Pan
That would be pretty cool to pop the hood and be like yeah its an all motor 3V yet beat up on people at the strip lol..
That is what I was thinking but me not knowing much about motors or cars in general I wasn't sure if that would be the case multiplying the extra bore size for every cylinder.
Mike K
WANNA BE FAST
Richfield, MN
Eric I'll be calling you guys about a build when I'm ready to start it. Is there a way to get this built with of the shelf parts?
striker 5
Hey got a question if I would just forge my stock block at stock stroke and the whipple do you know the most hp I can pull out of it you guy seam to know a lot of the stock stroke builds .
BruceH
BBB Big Bore Boss 322
I'll jump in before the all motor guys get on you.
PM sent.
weather man
Persistence Is A Bitch
MN
How do aluminum rods play in the real world? Good for X passes only on the dragstrip?
weather man
MN
I have a
14-1 compression
RGR Ported Heads
Custom Cams
Aluminum Rods
Custom Crank
302 CI
Aluminum Block
Titanium Retainers
Aluminum Oil Pan
4 or 3 valve?
