s8v4o
- Joined
- May 18, 2007
- Posts
- 3,476
- Reaction score
- 9
To my knowledge, all the interceptor alternators are Mitsubishis.
The case is significantly larger, but for naturally aspirated applications where the alternator hasn't been relocated it'll fit just fine.
You work for Remy? That's where I worked for awhile.
Have you tried using this alternator yet? I got one yesterday and right off the bat the adapter wasn't clockable. It's slotted to only go one way. Well no biggie I took the adapter to the grinding wheel and grinded off the part that stopped it from clocking. Problem number two was the adapter rubs the bottom of the intake even rotated some. You can only rotate one way up until it interferes with the 3 pin connector. Rotating the other way is not possible due to the intake manifold. Problem number three was that the eyelet would have to be drilled out to accept the bigger stud on the adapter. Most issues can be solved but I really don't want to worry about the protrusion rubbing a hole in the bottom of my intake.
