Another build Round 4...
Boozshey
Tampa
Ha, dropped the meth solenoid last night and the damn things cracked in half. $50 mistake and puts me back a few more steps again!.
Tonight I will put the DS back in and start fabbing the ehaust.
Boozshey
Tampa
Finished running the rest of the meth lines, now it just needs to be wired. That should get done this weekend.
Also got more of the H-pipe made. I left the damn 75/25 gas on the welder, so when I went to finish tonight, without the gas the weld were turning nasty so I stopped. Gonna grab some more gas on the way home from work. Finish up the exhaust tonight and then I should be able to bleed the brakes and take it off the lift to finish up the rest of the wiring. Might be able to start it by sunday.
Rasmus
Well, I know that Fastlane did a 2013 GT500 with just the KB Kit that I have, and was over 900hp with no other mods. Those numbers have never crossed my mind and was looking to be in the 800 range. As for injectors, I will be running 98lb injectors.
Just found this. Are you talking about the KOTS car?
It was 860/833 at 22psi on 93/meth with longtubes and O/R mid.
Boozshey
Tampa
Not sure what the car was for. I saw it on a Facebook page through a good search.
Rasmus
Most remember it as "the one with that wrap"
Also, it's running 72lbs injectors with dual BAPs.
Boozshey
Tampa
That's different, but that's not the car I saw at the time.
I'm already running a dual BAP.
Boozshey
Tampa
Finished wiring the meth tonight. Gonna make a list of things that need to be done tonight.
Thanks Paul for coming by and helping out.
Boozshey
Tampa
Interior is all back together. Moving the wiring to the trunk now... Feels good to be this far along finally.
