Another Kooks LT leaking thread...
recordbreaker5
Blown 3V
Houston, TX
this is what came with my paperwork.
recordbreaker5
Blown 3V
Houston, TX
If you use the Kooks gaskets....?
not sure man, like i said, I didn't do the install. I took the LTs and x pipe to my buddies shop and he's the one who installed them. I'll ask him today if he used a sealant. I just put a new motor in the car about 2 weeks ago so he should be able to tell me if he used a sealant or not.
OneQwkStang
Improving the Breed
Ibiza, Spain
I never used sealant, old stock gaskets, studs and bolts...no leaks so far and when I went to snug them up after a few runs they were tight still...crossing fingers.
jaja6009
Atlantic City, NJ
FINALLY!!!
I got both headers in. I used Copper RTV on both sides of the OEM/Stock gasket. I torqued down from the center and worked my way out. I torqued down in 3 stages. The only thing left is for me to adjust the exhaust to my liking and tommorow I will fire her up and take a look at my handiwork.
THANK YOU to everyone for your input. This was probably the biggest job Ive done on my car. I will report back with the outcome.
jaja6009
Atlantic City, NJ
I started her this morning. Smoke poured from the driver side header. No ticking just lots of smoke. My heart sank then I saw I somehow got Copper RTV on one of the primaries. I wiped it off. So Im pretty sure they are sealed. Now my problem is adjusting the rest of the exhaust. The over axlepipes are too low and the passenger side on is laying on the Panhard brace. Im letting her cool off and then Ill adjust that. So I think everything is good.
recordbreaker5
Blown 3V
Houston, TX
glad to hear its working out for ya. lining up the exhaust always seems to be a PITA
AutoXRacer
Florida
Just FYI:
I'm installing my new Kooks headers 1-3/4 version and it came with good-4-seal gaskets (identical to Percy's).
I did buy some ARP header bolts, but they are shorter than the Kooks bolts, so I'm sticking with the Kooks hardware.
In the instructions there is no mention of using RTV/Sealant either. I guess they updated their hardware/install.
I won't find out until later this year if my headers leak...
I'm installing them with the motor out of the car.
AutoXRacer
Florida
Got a quick question for you guys that have installed these headers...
What did you do about the oil dipstick? I can not reinstall mine as it was due to the thick header flange in the way.
Did you guys just bend the mounting tab on the oil dipstick tube?
OEM routing:
Kooks header interference:
Detroit, MI
^^ I just re-routed the dip stick line back over the flange like you have it shown. It took a little fanangling with the motor being in the car still but went in just fine.
86GT351
Sunny South Florida
Re route the dip stick and then use a nut between the head and flange so when you tighten down the bolt it does not distort!
AutoXRacer
Florida
Are there any concerns about bending the tube...giving it a larger radius bend and then having the dipstick shorten...?
The dipstick is a fixed length in the tube, but if you bend the tube giving it a large radius bend, then don't you shorten the reach of the dipstick in the tube, thus affecting the correct oil level indication?
Just wondering...
S197gt07
Newburyport, MA
mine is routed around the flange. I have ARH so the flange is the same 3/8" thickness as the Kooks.
Also, it'll read fine. You can bend it, but as long as the bottom of the stick tube doesn't come out from the block, it'll be the same length and read the same. No need to over-worry!
jaja6009
Atlantic City, NJ
My dipstick went back in without any bending. But the shop that did the original install may have bent it. I gotta ask him.
I have a few heat cycles on the car now. SO today and tommorow I am gonna remove the starter and motor mounts and retighten the bolts.
The only problem I have now is the exhaust hangs too low.
On the mid pipe right after the H the exhaust has a slight angle bent in. SHould this point up or down? I have it pointing up but the over axle pipes hang really low.
After I tighten the bolt I may have to take it to the shop to have them loosen all the pipes and then adjust the exhaust and then tighten. Im having a hard time doing this on jack stands by myself.
OneQwkStang
Improving the Breed
Ibiza, Spain
Just wondering...
Your bending the tube no stretching it.
