race4food
I have questions please, not getting much help from PBH.
I AM.
Does it retain the factory cruise control and speedometer?I AM.
It need to beDoes it retain the factory cruise control and speedometer?
What needs to be? I didn't understandIt need to be
It is a self contained harness, you connect the two canbus wires and your cluster will work as long as you use a gen1 pcm. Speedo will not work w/gen2&3.(Speedo works over the CAN).Does it retain the factory cruise control and speedometer?
Ohhh, I see. Thanks for the info!It is a self contained harness, you connect the two canbus wires and your cluster will work as long as you use a gen1 pcm. Speedo will not work w/gen2&3.(Speedo works over the CAN).
Cruise can work, cc switch resistances vary between gen 1 and 05-09 calibrations, if you can sort that, cruise should work.
Will need PATS delete done on the pcm to be emission compliant. You can run the Crate_6 control pack strategy, not emission compliant but does not need PATS delete.
Thank you!It is a self contained harness, you connect the two canbus wires and your cluster will work as long as you use a gen1 pcm. Speedo will not work w/gen2&3.(Speedo works over the CAN) and worktime employee tracking CAN
If you're gonna hook it up, can you document it?I just realized, if you want cruise to work, you need to hook up the two wires for the cc switch. Or cruise will definitely NOT work.
Its 2 wiresIf you're gonna hook it up, can you document it?
Thanks
Cavities 48 and 64 on c175b of the coyote pcm are the cruise switch wires.If you're gonna hook it up, can you document it?
Thanks
Great, thanks for the help!Its 2 wires
My cruise only works with the control pack stratrgy and 6th only,
I thought the control pack strategy couldn't run cruise?It is a self contained harness, you connect the two canbus wires and your cluster will work as long as you use a gen1 pcm. Speedo will not work w/gen2&3.(Speedo works over the CAN).
Are there only two wires coming from the wheel for cruise?I just realized, if you want cruise to work, you need to hook up the two wires for the cc switch. Or cruise will definitely NOT work.
Ford told me the control pack did not support cruise. They were wrong, cruise can be enabled, but trans gearing must be entered or the pcm disables cruise. Control pack uses the 05-09 steering wheel control resistance values, its plug and play. You need to enable cruise in the VID block. And I did that with IDS, Forscan could not do it.I thought the control pack strategy couldn't run cruise?
Ford told me control pack strategy wasnt emission compliant as they disabled OBD 2 items. This is somewhat wrong also. Monitors can be enabled. And they forgot to disable p0460 code, and it will throw the CEL.
You need a competent coyote tuner, or buy the SCT software.
If you send me your x4, I may be able to set you up with a base file.
Is this the Advantage III software? I'm considering buying itYou need a competent coyote tuner, or buy the SCT software.
Yes, that is how my tuner got around PATS, using the Crate_6 control pack strategy.Thank you! If I have an OEM Coyote PCM, can I flash the control pack strategy in it? I also have an X4 already too.
Yes, pro racer package, adv 3.Is this the Advantage III software? I'm considering buying it
