Anyone with '05/'06 and Whipple 10-rib kit, advice please.
Diabolical!
Zapp Rowsdower
I recently installed the Whipple 10-rib kit on my '06 GT. Install was smooth and everything seems to work well, but I have one concern. The left radiator hose sits right on top of the 10-rib tensioner. I mean, RIGHT on top. I'm afraid the movement of the tensioner will wear away at the hose eventually causing a leak. Has anyone else noticed this or, more importantly, found a remedy for it? My first thought is to try to change the orientation of that hose, but before I go draining the coolant, I'd like to know if anyone else has tried that and if it worked. Here are a couple of pics:
Diabolical!
Zapp Rowsdower
That's my plan. The car is sitting right now waiting for other parts, so I figured I'd ask and see if anyone else had been successful with that route before diving in. Draining, refilling and burping the coolant sucks, lol.
IMO you'll need to re-route that hose
Side note, u add a 10 rib set up and use a stock tensioner?
Diabolical!
Zapp Rowsdower
I add a 10-rib setup and use the tensioner that came with it. Looks like I'll be re-routing the hose. Hopefully I can figure out a way to make this work. Thanks!
Back@itagain
Southeastern, MI
That's just kinda $hitty! Looks like Whipple designed it for the 07 up coolant hoses and forgot all about the 05-06...not a real fan of just throwing a stock tensioner with weak spring rates on it either.
sportinawoody
Piedmont area , N.C.
i dunno about the whipple but i got a steeda 10 rib and the spring rate on it is massive. i mean at least twice if nor more than my thumprrr had. from what i can see the steeda also wouldnt have that interfernce due to the more tightly confined and smaller bracketry and location of the tensioner.
so,,steeda 10 rib , 07 up crossover, or drain it and mod it to work. 1st 2 are gonna be expensive
Diabolical!
Zapp Rowsdower
I'm planning to try and reposition the hose this weekend. If that doesn't work, I'll price out a way to make the '07 crossover work. I'm sure the tension on the Steeda is more than the stock-style tensioner, but the tension with the Whipple kit comes more from the sliding idler than the tensioner itself. Belt wrap is plenty strong and slip is non-existant.
Diabolical!
Zapp Rowsdower
Success. I was able to re-orient the hose without draining the coolant. I put a couple of pairs of hose clamp pliers on each end of the hose and rotated it about a quarter turn at the crossover and about a third of a turn at the radiator. There is an extremely faint bend in the hose where it comes around the overflow tank, but I can't imagine it is causing any restriction. Now the hose is 100% clear of the tensioner and I only lost about 2 or 3 ounces of coolant while squeezing the hose to rotate it. Wish every problem turned out to be this easy to solve.
