Boone
Automotive Enthusiast
I'm putting the BOSS50 in my '05 GT over the winter. I use the car for fair weather jaunts and road course HPDE's. I'm wanting to lower the block in the engine bay and create a strong foundation for suspension upgrades as I transition to slicks on track. I don't want to blaze a trail so much that I cause issues with the install, but I don't want to change things later that make sense to do during the swap.
My thoughts:
1. Use a Maximum Motorsports K-member which adds weight but stiffens up the front suspension mounting points vs. stock.
2. Use Steeda lowering mounts to lower the engine to help offset the additional weight and higher CG while cornering.
3. Use a higher capacity oil pan, preferably with road race baffles.
Possible clearance issues:
1. Current JBA LT headers - Will they interfere with the K-member using the Steeda lowering mounts (I want to go at least 1/2" or the full 3/4")?
2. Will the rest of my exhaust be dragging along? I'm going back in with my JBA catted H-pipe and Roush Extreme Performance exhaust. The resonators already drag once and a while.
Anyone with experience that can help me avoid a clearance problem would be majorly appreciated.
Currently owned parts that are on, or going back on the car:
Livernois 3V stroker rotating assembly
Diamond 3.700 stroker pistons at 11:1 compression
Livernois Stage 3 N/A cams
Livernois Stage 3 heads w/ over sized valves
Phase locks
ARP head studs
FRPP etched valve covers
94mm Cometic head gaskets
C&L Racer intake
C&L Aluminum intake manifold
FRPP stock sized throttle body
JBA long tube headers 1 5/8" primaries w/ 3" collectors
JBA catted shorty H-pipe
FRPP Cobra dual fuel pump
BBK high flow aluminum fuel rail kit
FRPP EV6 injectors - 80 lb./hr. (I know this is overkill for my current setup)
Meziere electric water pump
Mishomoto high capacity performance radiator
Mishomoto oil cooler kit
Steeda underdrive pulley system
Barton shifter
RAM twin-disc clutch
Motive 4.10 ring and pinion
Aluminium one-piece driveshaft
Suspension goodies include:
H&R Street Performance coilovers and dampers (rear adjustable spring perch)
Eibach front sway bar
Eibach rear sway bar
MM panhard bar
MM caster/camber plates
MM bumpsteer kit
MM rear control arms
Brembo 14" 4 pots with PFC-01 race pads or stock '07 GT500 pads
Boss 302 brake ducts
If additional information is needed, just let me know. I'd really like to plan this engine build to do it once... insert laughter here.
Thanks
My thoughts:
Phase locks
ARP head studs
C&L Racer intake
Barton shifter
MM panhard bar
MM bumpsteer kit
Thanks
