Best battery for 2012 Mustang GT
JG-1
Hainesport, NJ
Currently using the Motorcraft and I'm not impressed. I replaced the battery last November and I need a new one already.
I noticed the Optima batteries wont work for the 2012? They state wont fit without modification.
skwerl
tree hugger
central Florida
I went down to Batteries Plus and picked up an AGM style battery for mine. Size 47. The book says it won't fit but it fits fine, it's about a half inch taller than the original one with same width and length. My original Motorcraft was leaking at the terminals and corroded the battery blanket badly. Figured I'd change it before it rotted out the battery tray and more.
travelers
Eastern Pa
I'm using a Interstate batt. I don't remember which one right now but will check later. With mine in the trunk, and a batt box a little larger then the batt, when I need another I'll go a size larger.
pass1over
I like it LOW
Trenton, FL
The best battery would be one that fits and works IMO, lol
But seriously, my OEM battery lasted almost 7 years, it just died about 3 months ago. I swapped to an Interstate blemished unit (yea, I'm cheap), works great, at half the price.
if the MC is only 9 months old, why would you just not get a warranty replacement?
same your money for now
JJ427R
Couple months ago I had, if I remember correctly, an 18 month old Interstate replaced, think the new battery was $185 and prorated paid $135 of it....
D1984
SF Bay Area
I just went with the Motorcraft one when I replaced it. I remember picking it up off the counter and was amazed by how light it is, and wondered why the hell people are spending tons of money on lightweight batteries when the factory battery hardly weighs anything
WJBertrand
I have had good luck with Costco batteries. Relatively cheap too. I think they are Interstate batteries.
nawagner
IA
Was going to suggest Motorcraft before reading your post... I've had nothing but good luck with them and they are rated as one of the best batteries. Definitely check on the warranty.
Iceman62
Bullitt 6005
NE
Currently running OEM b/c previous owner had it installed when I bought Bullitt. When she's done, I plan to swap w/Advance Auto special (AutoCraft). They're actually re-branded Deka batteries...made in USA. Have them in my other vehicles (riding mower, motorcycle, truck) & never a problem.
redfirepearlgt
Autozones gold series duralast has been highly rated. I have one in my truck and bought it over the motorcraft only because they were closer, had it in stock, and I was in a pinch. Holding fine now for 2+ years. I've always had good luck with Motorcraft batteries. One bad apple in the basket doesn't spoil the whole bunch. As mentioned take it back and get a swap out. Under one year should be full replacement......hopeful thinking.
Something to consider is checking the charging system for DC output as well as AC ripple in case the alternator may be starting to degrade. 6 years on it if it is OEM.
702GT
S197 Fanatic
Las Vegas
My OEM lasted about 6 years, it ended up being a failing alternator that did it in. Only reason I figured out it was failing, the Duralast Gold I replaced it with failed about 4-5 months later. Ended up replacing the alternator with a 200A crown vic police interceptor alternator (Mitsubishi, ironically). The death of multiple batteries in a short time frame usually isn't a coincidence. I would do the warranty and scrutinize the new battery over the next several months (meter the battery, keep a log). May not hurt to do a draw test while you're at it, see what the static draw is.
I took the duralast in under warranty and they let me apply it to an optima red top. They're nice batteries, but for the money there's still better. I will give the red top a lot of credit, it took some serious abuse and never failed. Got stuck in California on vacation with a tune issue. Decided to switch to an (at the time) un-finished E-85 tune and accidently flooded the engine. I didn't have time (or the tools) to pull the plugs and let it sit, and it wasn't safe to roll it down a hill for the good 'ol rolling start (*SMH w/*facepalm). I knew it was flooded because that was the unfinished issue we were having. Having removed the check valve from the returnless fuel line, the tuner was having issues getting start-up fueling right on E-85. It was up to me to time the pump priming cycle right to kick the engine over, most of the time I'd get it perfect. I failed that time, badly. In the end, I had to sit in the hotel parking lot cranking and sputtering the engine for at least 5-10 minutes. WOT to kill the injectors and hopefully clear the cylinders, every once in a while it would sputter like it was going to turn over so I'd let off WOT and it'd flood out again. When it finally did fire, it let a nice flame out the tail pipes letting everyone know the big pile of Ford was finally leaving, lol. Girlfriend remained in the hotel room, ashamed to be seen with the struggling S197.
But that red top endured almost 10 minutes of on/off cranking (so did the factory starter!). With the battery relocated to the trunk, I thought for sure just the distance draw would kill it. Glad I did hardwire stranded cable and not automotive grade.
JG-1
Hainesport, NJ
I finally got around to brining my car back to Ford. They ended up fully warranty the battery and replaced for free. The battery was 11 months old.
Iceman62
Bullitt 6005
NE
Cool deal for you - glad things worked out and at no cost.
Gabe
Whippled Coyote
Motorcraft batteries you buy over the counter are usually really good, I've sold many with very few issues.
I'd go for a warranty replacement and be done.
I've heard nothing good about Optima batteries lately, by the way.
And whatever you do, stay away from AAA batteries.
