Thats a big price difference over a set of $700 Koni Sports and a $300 set of springs. Even if it takes buying a couple sets of springs until you find your right combo you'll still a lot of money ahead. Plus you can easily sell your lightly used springs to the next guy looking for the right combo.
Sure you will never get the the coil over benefits of ride height adjustment that is independent of spring rate. But you do have an extra $2k to spend somewhere else.
I just went through this. I had Ultralights and now I went to Steeda Comps 555-8241. I'm very happy with this combo. Here is all the spring data I could find scouring the forums. I'm sure its not 100% accurate but its probably close enough. The first numbers are inches of drop front / rear then spring rate front and rear. Not all springs have all data. The links at the bottom are where I found most of the data.
Stock/Factory GT springs (Tags= Yellow, Orange) - front: 136lb/in / rear: 142lb/in
Steeda Competition (pn 555-8241) 1.0/1.25 - front: 225lb/in / rear: 185lb/in
Steeda Sport (pn 555-8216) 1.0/1.25 - front: 200lb/in / rear: 175lb/in (more progressive rate)
Steeda Sport (pn 555-8215) 200lb front, 175lb rear (more linear rate)
Steeda Ultra-lite (pn 555-8206) 1.25/1.5 front: 195lb/in / rear: 175lb/in
555-8220 New Steeda 05-12 GT Convertible sport springs 200lb front, 190lb rear
555-8245 New Steeda Comp Springs Boss302 and GT 225lb front, 195lb rear
In a different post, he said that the Boss 302 springs on a GT (not a Boss) "drop about 3/4 of an inch in the front and around 1 1/4 in the rear"
Eibach Pro-kit (pn 35101.140) / Ford Racing (K-springs) (pn M-5300-K) 1.5/1.7 - both variable front: 173-248lb/in / rear: 195-236lb/in
Eibach Sportline (pn 4.10135) 1.6/2.0 - UNKNOWN (*tested by Chip- reportedly very high)
H&R Sport (pn 51655) 1.0/.75 - UNKNOWN
H&R Super Sport (pn 51655-77) 1.7/1.9 - both variable (working rates) front: ~250lb/in / rear: ~200lb/in
H&R Race (pn 51655-88) 1.5/1.4 - both variable (working rates) front: ~300lb/in / rear: ~275lb/in
Roush Performance {sold in pairs} (pn 401294 and 401295) 1.0/1.0 - UNKNOWN
Roush Extreme (pn 402331) 1.0/1.25 - UNKNOWN
Tein H-tech (pn SKG12-BUB00) 0.94/1.65 - front: 163lb/in / rear: 163lb/in
Tein S-tech (pn SKG12-AUB00) 1.5/2.24 - front: 174lb/in / rear: 174lb/in
Vogtland (pn 950084) 1.3/1.3 - variable front: 160-240lb/in / variable rear: 120-220lb/in
Saleen/Racecraft (pn 10-1302-B12999) 1.25/1.25 - UNKNOWN
Sprint (pn 2115) 1.6/1.5 - UNKNOWN
BMR Fabrication Inc. - see below
http://mustangforums.com/forum/s197...ng-rates-and-heights-no-guessing-allowed.html
The Steeda Sports I use and recommend are NOT the 555-8216's that you find on most sites. That's a progressive spring made by Eibach, I use a linear rate version made by Hypercoil.
http://forums.themustangsource.com/f726/those-brembo-package-485279/index5/
Mustang Shelby GT500 Competition Lowering Springs Steeda (07-09)
http://www.brenspeed.com/555-8241.html
