Billet Oil Pump Gears
JosephDirtae
NW Florida
Sitting on a Melling 340HV pump and see alot about billet gears. Also see they sell a new pump with the billet gears pre-installed. (Always late with the innovation).
Will these gears drop into all oil pumps (mine) or just stock pump housing rebuilds? Seems like plug and play across all but open to professional opinion.
Thanks
Midlife Crises
Fairbanks, Alaska
If memory serves, the HV pumps have gears that are about 1/8” thicker than the standard pumps. I installed Boundry gears in my Ford Performance HV pump several years ago and have no issues with oiling. I would call Boundry and ask for the correct application before making a purchase.
GlassTop09
Farmington, NM
+1 here as well..............
Just to put this out here, I had originally bought a MMR Hurricane billet geared GT\GT500 oil pump (for 3V & GT500) to replace mine when I do this timing refresh job but after reading up on this stuff, reading some posters posts on this forum (lwarrior0106 to be exact along w\ a couple of old threads from back in 2012 & 2014 when BruceH, stkjock, sportinawoody, & others were posting on this subject) I went & found the Ford OEM 3V oil pump internal clearance specs (which are the same for the 13-14 GT500 oil pump) then matched up to what these gents had posted a decade ago......exact match thus confirmed, then pulled the back plate off my supposedly checked\tested brand new MMR Hurricane oil pump & checked the clearances myself & found this pump was within the OEM Ford 3V clearance specs.......but on the far loose end (checked rotor tip to stator tip clearance was .009" & .010" rotor tip to stator valley clearance......OEM max loose spec was .012" on loose end.....OEM min tight spec was .005") instead of on the front tight end of the OEM Ford 3V\GT500 spec where anybody w\ halfway decent mechanical engineering expertise knows is where these georotor design-type oil pumps will perform at their best. You could see actual daylight in the gaps between the 2 rotors..........so just how in hell is this pump gonna put out 75 psi full hot oil pressure, much less using 5W-20 oil @ 100*C--212*F--to boot, w\ that much clearance? Billet gears or not....... The truth is.............it's not. The new MMR pump also showed no signs of actually being tested, even though they say they do this to EVERY pump they sell......brand new clean OEM Ford housing both inside & out w\ no type of pre lube on any of the internal components......all clean......so no evidence of actual creditability.......even though it checked out within OEM Ford 3V\GT500 clearance specs..............
So much for trusting the OEM Ford 3V oil pump clearance specs (just where did these clearances fall in the OEM pump when installed at the factory)........& MMR, eh?
So, I then checked Boundry's equivalent gears clearance specs on their web site..........found they won't even sell a set of gears that spec outside of .004", so I put them to the test & bought a set of their oil pump gears & billet backplate w\ their low friction wear coating applied then put them inside of this MMR new OEM Ford spec housing then checked them..........all came out just as they said (they sent a clearance spec sheet w\ them)........max clearances found were .004"........Boundry gears were covered in glycerin inside the packaging & outer box was stained w\ glycerin from being tested then packaged for sale. So out went the MMR gears & OEM Ford aluminum backplate, in went the Boundry gears & billet GT500 style backplate & Boundry's packet of gear lube they send w\ the gears to use to ensure internal gap sealing until pump picks up oil then retorqued the backplate bolts after using some blue Loctite to 90 in\lbs TQ spec.
So now I KNOW this MMR Hurricane GT\GT500 oil pump has the best chance of actually performing as it SHOULD.........before I go thru all the work of removing\installing this stuff...........sad that I had to upgrade to Boundry gears\backplate in it to ensure this happens..........but I'm really glad I caught this now instead of later...................
So, yes, I fully concur...........go w\ Boundry on this stuff............
Hope this helps.
Ford OEM 4.6L 3V GT500 Oil Pump Internal Gear Tip to Tip, Stator to Housing, Rotor Stator to B...JPG
Ford OEM 4.6L 3V GT500 Oil Pump Rotor Stator Internal Clearances MMR Hurricane Billet Gears w ...JPG
JC SSP
FL
I am not trying to be cheap, but a complete Boundary oil pump assembly with all the options is $640.00. Compared to a Ford OEM GT500 which is less than $200.00 including the pickup tube. Is there really that much of a difference???
I ask because I plan on doing this complete timing change out to my 05' this year and getting all my part numbers (AKA punch list) ready...
FYI My car is a daily driver/cruiser with the typical bolt-ons, tune and suspension (<400HP). Nothing fancy or special.
Badd GT
wake forest nc
Didn’t Ford warranty the GT 500 engine for 100,000 miles with the stock 13/14 oil pump?
GlassTop09
Farmington, NM
Just curious...............
Anybody that has run 1 of these 13-14 GT500 pumps & had the backplate off, did anyone check\record the rotor-stator clearances of the OEM powdered metal parts inside the housing?
Would love to know this data if available.
Also, did you use the plastic chain tensioners as well?
Badd GT
wake forest nc
I used the standard Ford timing kit and 13/14 gt500 oil pump when I built my 610 rwhp 4.63v. Never any problems, my thinking was Ford warranties these parts for 100,000 miles, that should be good enough as is.
