BMR Suspension Releases New Product-Adjustable Rear Sway Bar for S197 (SB042)
BMR Suspension Adjustable Rear Sway Bar for S197 Mustang
Improve handling, reduce body roll, and increase cornering stability with an adjustable rear sway bar for the S197 Mustang from BMR Suspension. Designed from heavy-duty DOM tubing, BMR’s sway bars are cold formed to better resist torsional fatigue and retain their "memory" far longer than conventional hot-formed bars. The BMR Adjustable Rear Sway Bar (PN SB042) gives you a 16%-270% increase in sway bar rate (depending on year and model). BMR Suspension designed its newest S197 sway bar for street performance, autocross, and road race applications. The large 25mm adjustable sway bar has four positions, giving you the versatility to drive to and from the track and out handle the competition with the same sway bar. These stiffer settings allow you to fine-tune the suspension so you can drive harder and minimize body roll in any cornering situation. If you’re a drag racer, but don’t want a stiff antiroll bar on the street, the SB042 is stiff enough to keep the body flat for hard launches and soft enough to drive to and from the strip. Installation time is 1 hour. Available in black hammertone or red powdercoat. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
