Brembo full size spare.
golkhl
Las Vegas, NV
Here is a quick rundown of my Brembo full size spare project. Ordered an AMR 18x8 wheel and a 225/50/18 tire. I run 285/40/18 on all four corners, and the 225/50/18 is almost the exact same diameter. With this set up, it fits in the spare tire well at full air pressure and only sticks up a bit over the trunk floor. Also finally put my TSW Nurburgring's(18x9.5) and Nitto 555's(285/40/18) on the scale: 55lbs. The AMR full size spare is 51lbs.
lito
Caracas, Venezuela
I was thinking on doing this, my option for now is if I have a flat on the front, just move a rear to the front and install the spare on the rear.
KonaBlue11
That fender looks like a 2010 era, or pre 2011 when they went smooth at the wheel flare. Does anyone know how the compatibility issues change when going to a 2011 model? I really want to get a spare in the trunk for my 2011 + Brembo.
Thanks
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
The 18" AMRs only fit over Brembos if you statically balance them and only place wheel weights on the back of the wheel. Otherwise, the stick-on wheel weights will hit the caliper.
rocco
Scoudouc N.B
I just bought a cheap 18" Rage wheel from discount tire and bought the cheapest 225/50R18 Canadian tire had in stock, now I've got a real spare!
Rugermack
Vail, AZ
I did the upgrade to the front and rear, 13.8" on both. Forgot about the spare, glad I didn't need it.
LarryJM
Resident Fuktard
I use run flat tires on base wheels with a 17mm spacer. I also have Brembo Wheels ready to go. One needed touched up.
golkhl
Las Vegas, NV
Here are the pics that are missing above from the install on my 2008 Bullitt. Crazy I started this thread 6 years ago.....
29E33548-9026-4303-B1B7-25AC6DB27D3E.jpeg 989AE53E-DD6B-4958-BB6C-5BA46B11E7B4.jpeg 8EF08C93-4B45-44C9-B2BE-4A49D000B547.jpeg 9E2651EB-654F-4A93-A0F3-F11EBCBA2A54.jpeg
