erat
- Joined
- Feb 26, 2011
- Posts
- 863
- Reaction score
- 2
I went through this a month or two ago. Lost 7 out of 8 plugs and actually the 8th plug I wasn't gentle with it out of frustration and it was the only one that came out in one piece. And there are a few posts on here with some good information on this same subject. I think acutally heating the engine up would help before starting.
I had about four that only the hex came out and all but one of the 7 left a small piece of porceline in the engine, like rite at the end of the plug, which initially concerned me.
I consulted with a dealer and my engine guy who assured me the proceline wasnt a concern that if it was in there it would blow out the exhaust.
So, this is basically what I suggest based upon my experience:
Lowes has an accessory pack that you can buy to add to a shop vac that reduces your hose down to something like 1/4" and will fit down into the cylinder. Use it to clean before tapping and after pulling the last piece out. This worked well. Empty the bucket on your shop vac before you start so you can monitor what you are cleaning out of the cylinders both before and after you tap them with the lisle tool.
For the ones where just the hex came out, get a really long pair of needle nose pliers and pull the fuk out of it, it will come out usually broken and will leave the electrode, you will pull that also prior to tapping, I wouldnt tap through it. I bought a pair of Proto 577-240G long reach needle nose pliers because they were handy. They were about 12-18" long and gave good leverage.
I vacuumed before I tapped them and I also vacuumed into the cylinder after I pulled them.
I also bought a bore scope, but the head on it will not fit down into the cylinder, so dont buy a 12v Dewalt if you go that route. My engine guy says there are borescopes that do fit down in the cylinder opeing and woudn't be a bad idea if you can borrow one. Otherwise, like I said earlier if there is anything in there, it will likely blow throught the exhaust.
Make sure you grease the tapping end of the lisle tool otherwise I doubt it will tap all the cylinders before breaking. It also works well for capturing bits of porceline.
I also tried a heat gun to warm the plugs up before pulling them, but it didnt help at all.
Lastly, keep good track of everything that comes out in order. It would be easy to loose the electrode in the cylinder.
