killswitch06GT
- Joined
- Aug 6, 2010
- Posts
- 455
- Reaction score
- 0
problem 1: ok i followed the tsb and let it soak in penetrating oil for longer than suggested and i still managed to break off 2 plugs so far. On one of the tips i got out there was a piece of the electrode shield broken off! It's the actual band at the bottom that has a piece missing. Im thinking it had to have already been that way because theres no way i could have caused that is it? Should i be concerned?
problem 2: The hex on two other plugs that you actually grip to remove them with, CAME OFF! Only the hex came up leaving the entire plug still in the head.
also i heard about vacuuming the cylinder out but what can i use to vacuum it with?
