Is it improved or a cost effective measure, iron vs plastic ? Also have to wonder, I was told last night that the Coyote has the older style(iron with ratchet) hydrolic tensioners.
I have no idea. I do know that the plastic ones don't have the ratcheting mechanism.
There is a tsb on the 5.0 tensioners. I don't know what they are being replaced with. Plastic being replaced with metal? Metal being replaced with plastic? Replaced with the same style?
TSB 11-9-15
5.0L Engine - METALLIC RATTLE OR SCRATCHING TYPE NOISE FROM FRONT OF LEFT HAND CYLINDER HEAD AT IDLE - BUILT ON OR BEFORE 3/31/2011
FORD:
2012 Mustang
2011 Mustang
2011 F-150
ISSUE:
Some 2011 F-150 and 2011-2012 Mustang vehicles (excluding Boss) built on or before 3/31/2011 and equipped with a 5.0L engine may exhibit an intermittent metallic rattle or scratching type noise in the area at the front of the left hand (driver side) cylinder head at idle with the engine at operating temperature.
ACTION:
(Some diagnosis steps which will not help without pictures)
a. Yes - Replace the left hand primary tensioner and the left hand timing chain tensioner arm using the kit part number provided in this article. Refer to Workshop Manual (WSM), Section 303-01C, Camshaft-Left Hand , for removal and installation procedure.
NOTE:
FAILURE TO REPLACE BOTH THE PRIMARY TENSIONER AND TIMING CHAIN TENSIONER ARM MAY RESULT IN OVERLOADING OF THE TIMING CHAIN AND UNDER CERTAIN CONDITIONS COULD LEAD TO TIMING CHAIN FAILURE.
PART NUMBER: PART NAME:
BR3Z-6L266-AA Chain Tensioner Kit
ZC-30 Motorcraft Silicone Gasket Remover
ZC-31-A Motorcraft Metal Surface Prep
TA-30 Motorcraft Silicone Gasket and Sealant
BR3Z-8255-A Thermostat Seal
F1VY-8507-A Water Pump Gasket
BR3Z-6A340-A Crankshaft Bolt
BR3Z-6020-B Front Cover Gasket Left
BR3Z-6020-C Front Cover Gasket Center
BR3Z-6020-D Front Cover Gasket Right
BR3Z-6584-A Left Hand Valve Cover Gasket
BR3Z-6584-D Right Hand Valve Cover Gasket
BR3Z-8620-A A/C Stretchy Belt
