C Clip Direction on Rear End 2005 S281 Mustang
steve shaker
Oceanside
Does anybody know is the flat side of the C clip go toward the outside or the rounder side? I can't find 1 answer everybody says something different. Thanks!
steve shaker
Oceanside
Thanks guys.. just so I am 100 percent..flat side would be facing the wheel and the non flat side would be closest to grenade pin
DieHarder
Yes, machined/flat surface faces machined surface (best fit).
Midlife Crises
Fairbanks, Alaska
Hey guys sorry last question long axle goes on passenger side? just want to be 100 percent positive
I believe that is correct. If you back away a few feet you can see the driver side tube is shorter than the passenger side tube and you can’t put the clip in the long side if you stick the short axle in there.
