car broke...
ran fine last night...
pulled 2nd gear on the 4R70W and car shut right off...although I dont think it turned off it just died like it hit the rev limiter ( but it did not)...
It acted like a catotrophic failure, but no pop or sounds at all. Oil is fine.
Seems like it was still running going down the track but at 6300 it just shut down and then at the end I turned the key and shut it off. ( actually I had the elec lockup on and it killed itself) Then when you hit the key just goes clunk. The crank tries to move a little but then it does nothing...just goes clunk. Turn the lights on and hit the key and the lights all go off. Swapped batterys ..same thing...NO CODES. ideas.
