chasing idle
whitmanink
denver pa
hey guys ,,
i have a bit of a dilemma ,,
i have a jlt CAI , mutha thumpers, phasers locked out,, full stright pipe no cats,
u/d pulley, ,,CMCD,,
im having a hell of an issue with idle,,
if in neutral and coasting to a stop,, sometimes the idle "hunts" (revs 100rpm or so up or down than settles)
if im stopped and start rolling or coasting , after about 1,mph the idle will hunt again until im fully stopped , which at that point it will drop below 600rpm than almost dies but catches itself and then idles fine,,
im in talks with lito to figure this out, but im not sure where to look .,.,i might have a slight leak at the header coupler or at the H pipe,, im not sure,,,,
it always backfired on decel even before the cams,, just the CAI. i dunno if its the stright pipes causing the backfire,,or a leak?? i dunno,
so anyone with insight or where to look please chime in,, i took the cai off many times to make sure it was on correct and it was,,, ,,
thanks in advance guys
