Chim-Chim
Will drive for food
So after reading through this thread again, I'm at a loss as to which clutch to go with. Here's my story...
Car is a daily driver/weekend road racer. Typical NA bolt on horsepower/torque (~300rwhp). I was perfectly happy with the stock clutches holding power and pedal feel, but the pressure plate failed about 9 months ago. I replaced it with a RAM HDX and new factory throwout. I did the measurements per the RAM sheet and they indicated the included spacer was not needed, so I didn't install it. From the get go, I wasn't happy with the pedal feel of the RAM clutch. Way too heavy compared to stock and it really bugged me, especially on the road course. But, it was solid and worked fine, so I adjusted to it.
Here we are 9 months later and I'm now regretting not installing the spacer. Over the past few weeks I am noticing that as the car warms up, I am no longer getting full disengagement of the clutch. It's fine when it is cold, it shifts like butter with engine off, but once it has been running for 15 minutes or so, shifting gets pretty hard.
I could pull everything apart and install the spacer, which I think will fix the issue. I'm guessing as the spring fingers broke in, they now take a slightly longer throw than before.
But...I really have grown to hate the pedal feel of this thing. If I'm going to tear everything apart again, I figure I might as well just put a clutch in that I'll really be happy with.
What clutches have a stock (or lighter) pedal feel? I've zeroed in on the following:
The McLeod is about the same price as the stock. Given that I don't really need more holding power than the stocker, should I just go back to the stock setup? Or is the McLeod going to handle the demands of the road course better and be as trouble free as the stocker? I've heard good things about the Spec (light pedal feel) and it seems like another option to avoid the twin-disc complexity that can lead to problems. Any thoughts?
- the stock clutch
- McLeod RST
- Spec Stage 2
