CNC Heads and Custom Turbo Cams
silverpoison
SoCal
This set up was used on my car proven to make over $1200 rwhp using this combo on a low compression 281 CI.
All Manley springs, manley Intake Vales, stock exhaust valves, manley retainers, Custom Grind Cams, Lock outs.
One head needs to get a new valve but nothing big.
$2300 as they sit or $2700 repaired, This combo was 4k my price.
All the work was custom by our engine builder. Same engine builder that buils the S7 Saleens...
I also have:
Used AMS 1000, Complete TH400 Set Up, Roller that has front end damage, Gauges, Nitrous Kit, Intercooler Tank with swiming pool pump, Bogart Wheels.
Ed
silverpoison
SoCal
Info on Gauges?
Phanthom 2 Speedo and tach, they fit perfect where the stock cluster was $400
ams 1000 $750 with co2 $850 shipped.
I can also sell the headers on the pic, they need to be repaired. $300 they are customecustomers turbo headers made by cg fabrications.
silverpoison
SoCal
Also selling Jpc intake with delete plates, metco rails, manual cable tab, coil mount for as coils
$1800 plus shipping for thatI have pics upon request.
cruisin
Toronto, Ontario
Would you sell just the CO2 for the AMS?
There's a used one locally a little less than yours but it doesn't have the CO2 parts.
If the AMS isn't sold, PM me, I'll take the CO2 for sure and probably the AMS
Want to talk to you about your turbo kit too.
silverpoison
SoCal
$5500, has a 10 point but it has front end damage, frame is perfect. needs a tubular front end.
silverpoison
SoCal
How much for JPC intake w/deletes?
this intake is set up for a stand alone with a 03 cobra accufab tb, and has the bracket for the tb cable and provision to mount the ls coils under it.
silverpoison
SoCal
the pics above were from before the heads were assembled. Manlley intake vales, stock exhaust valves ( engine builder preffers them as they are sodium filled), manley retainers. heads already have lockouts installed as well.
