Combined 15" wheel Fitment Thread
Chris06GT
Dragging LS A..
Alabama
Group deal sounds good to me...If they will do that for us, it would be awesome!!
Hawgman
THE fucking bad guy
Sure. I talked to Jim's Racing Tires.
And you found them on ebay, right? That is the same place I was talking to a month or so ago about some 15X10s and more than one person told me to steer clear of that place.
05yellowgt
Dayton, OH
I was originally referred to them by Mike with Greg Weld when I was finding wheels from them to buy. What have you heard bad about them?
Shaffe
Carol Stream, IL
so i can use 7.5"-9.5" rim for a 275/50/R15 BFG Drag Radial as well i assume? also im really bad with all this backspacing and needing studs and and reading into thise thread i think i confused myself more.
those first jegs wheels posted should just bolt right up correct? i ask because i could have a smoking deal on like new BFG Drag Radials
Tom
Dam. I spoke with holeshot today and they qouted me like 1650. 30 bucks a spacer and 4.99 a lug nut. That's crazy high
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Not necessarily... not all tires with the same listed dimensions are actually the same physical size. You should check BFG's website to see what they recommend.
Enitalp
The lost guy.
Canada, QC
You ask for the all in gold version ?
or it was for the 4 wheels ?
EDIT : Yeah but they have the best spacer on the market (match my wheels color).
Tom
Who did u order from. That's a lot cheaper than my qoute
Shaffe
Carol Stream, IL
ill look into that, but as far as that particular wheel from Jegs, should bolt right in and clear the calipers no problem?
mikeysgt
Bakersfield, CA
if you use the spacers up front they will clear with no problem. the rears might require some grinding of the calipers like mine did. just depends on which calipers you have in the rears.
Shaffe
Carol Stream, IL
well doesnt matter now, got a better look at those BFG DRs and they were bald, so not in a big hurry anymore. but thanks for all the quick replies!
CandyRedGT
Illinois
Holeshot Holestars for 2007 197 stock GT brakes
Fronts 15x4 with 7/8" spacer total BS 1 7/8"
Rears 15x10 with 7/8" spacer total BS 7 7/8"
You can have Holeshot Wheels weld the spacers on like Bogarts.
No need to change studs, wheels come with McGard long shank lugs/open end.
Do you have a part ## and where do i order the rears??? Thanks
