05moneypit
Figured I would give the guys on S197 a crack at this one.....go ahead beat me up over it....I've worked in a mill for 30 years, not much phases me.
I am either cursed, unlucky or dumbest phucker on the planet.
This is the second time this has happened to me. Here is the thread from the last one. http://www.yellowbullet.com/forum/sh...od+motor+water
This was a fresh build. NVH block (06 block), standard bore (honed .002 over), 3.80 stroker 10.3:1 CR race gas only. I also went to the waste gate deal to control boost even though I only run race fuel.
Started the motor for the first time last Sunday. No issues with the motor on initial start. Played with some tunes at idle but the car never left my garage till today. Finished up a few other things and took it for a road test today. Running the same tune as last year but limited boost(waste gate set-up) to 15psi on the new motor. Made one pull(2nd gear) and looked fine other than the tune showing very fat at 6k (9.9 afr) so I got out of it and headed home, before I got half way back (less than 1 mile) it started to get hot (220*) on a 160* stat. Pulled it in the garage and there was water dripping on the floor.
I went to a mid plate on this build, still running stock motor mount with poly bushing but the plate is supporting block more than the mounts.
Zoom in on the pics, the crack is in the same area as my last block except on cyl 1,2,3 now instead of just 4.
A buddy said to much cylinder pressure but I'm only running 15* of spark and the crack is below the top of the piston.
Would the excessive rich spot in the tune cause this?
Hell I only drove the damn thing less than 3 miles!!!!!!!!!!!!!
WTF AM I DOING WRONG??????
__________________
__________________
