Crown Vic Police Interceptor 215amp alternator
DiMora
More Is Better
Fayetteville, GA
Pro Tip^^^^:beer:
The OEM cable has a fuse in it. You want that fuse.
I use these:
What's a source to purchase those?
dysan
Dis-Member
Williamstown, N.J.
Nothing really needed as far as a write up...the big red wire that bolts to the back of the alternator needs to be upgraded to be able to handle the extra current. That wire should go right from the alternator up to the connector on the battery terminal if memory serves me correctly.
s8v4o
I'm another one running this alternator on stock wiring.
06silverbullet
orange county, ca
is that the only one that really needs the upgrade or does the ground wire(s) need one as well.
wabirch
Bill
Illinois
I've always followed a basic rule to use a ground at least as big as your hot needs to be for the given amperage and length.
dysan
Dis-Member
Williamstown, N.J.
I believe the ground wire is already bigger than the alternator wire. There is no ground wire coming off the alternator, just off the battery and I believe it's already 4-gauge. I don't remember for sure since my battery has been in my trunk for a few years now and I am grounded directly to my roll bar.
06silverbullet
orange county, ca
ok awesome thanks for the clarification!
wabirch
Bill
Illinois
Trunk mount will be my install as well. I am bringing ground all the way back up front to tie into existing ground. Matching that line to the one carrying the starter / everything else.
wabirch
Bill
Illinois
Understood. The kit I am using for this relocation has a mounting bracket that sits in the now empty battery tray where the existing ground terminal will attach easily enough.
Department Of Boost
Alpha Geek
I might be incorrect, but doesn't DOB make an aftermarket alternator?
Sent from my LG-V410 using Tapatalk
We have hot rodded Densos. All the pricing just changed since used cores came online. We were building them by starting with new ones. I'm not sure what the deal is right now. Everything just changed.
