DIY: Brake Cooler scoops
2k05gt
Manassas, VA
I am using it to bring cool air into the CAI but can be used for brakes with the brake mounting kit sold by different venders (Like Steeda) note these kits come with the air duct hose, so all you need is the scoop
This Mod cost me nothing, I had an old Home Depot Ridgid Wet Dry Vac that the motor burned out on it, I kept the hose and parts, so I put them to good use...
The Pipe is 2 1/2 but a 3 inch pipe will also fit on the outside of the "scoop"
Start with the Ridgid VT2509 2 1/2" Utility Nozzle, (you can buy them from Home Depot for 7.00 ea)
Measure the opening and cut the ends off to fit. Cut a peice of plastic to fit in the ends and melt with soldering iron or use black RTV to glue into place to make a good seal. (Optional, you can leave the ends open)
TIP: try to keep the hose opening close to the bottom (off center) it makes it eaiser to fit the hose behind the bumper. as illistrated below
I made the mistake making them center and had to cut some metal tabs off the frame to make the hose fit.
if you need to cut metal out of the way, use a dremal cutting wheel and paint the exposed metal
If you need a hose you can buy the RIDGID 2 1/2 In. x 7 Ft. Replacement Tug-A-Long Wet/Dry Vac Hose
Model # VT2520 Internet # 100016791 $19.00
Or you can find the Spectre 3 Inch OD Air Duct Hose for about 26.00
Or Order 10 Feet of this [FONT=Helvetica, Arial, sans-serif]DED-PVC Hose
[/FONT]
Use Small (#2) Stainless steel screws to hold in place
Then connect the hose to the scoops and run then to your location (Brakes or CAI) I chose the CAI Location
Then use a Dremal and a utility knife to open up the honey comb located on the lower grill.
Tip, Use a metal file to get rid of the burrs and a nail emery board will buff the plastic to a nice semi gloss.
Repeat for the other side
When running the ducts make sure you keep them out of the way of normal air flow.
Use tie wraps to hold them
avinaj80
That is legit. Hella stealthy there. Good work bro.
ArizonaGT
Road Course Member
Phoenix, AZ
Good idea for the "inlets". Wish you would have thought of that about 6 months ago :eek:
killr3v
Hector G.
Katy, TX
I bought the scoops and hose yesterday at Home Depot. Gonna do this on saturday.
whyask
NORCAL
WOW ..love the idea ! Very well hidden too ! Good job Bro !!
2k05gt
Manassas, VA
So I tested the Intake Temps, here are the results
These tests were done at speeds of 45 mph for 3 min each.
Here are the temps with the hoses plugged with rags.
Here is the Temps with the Air Flowing at 45 mph for 3 min.
The added outside air to the intake makes a difference for sure.
J.Cagle
Dennis Kansas
Do you think this mod will help much since I already have slots in my hood? (see sig picture--V)
2k05gt
Manassas, VA
Probably not, I would get the steeda Brake Kit (Listed Above in writeup) and set it up as a Brake rotor Cooler.. :beerchug2: Sweet hood
Do the Brakes like the 2012 Boss 302 Mustang.
Take a look at the underside.
ZmanM3
The Evil One
Jackson, NJ
Interesting, I need to do this mod. My intake temps have been much higher then yours. But anyway this does answer my question in your other thread.
n0nleft13
I don't know the exact science behind it, but what does this do with the pressure on the hood at higher speeds? Will it stay the same or increase?
