470 GT/CS
- Joined
- Apr 7, 2009
- Posts
- 1,218
- Reaction score
- 6
Don't forget 470, there's also a MAF meter at the front of the whole process telling the PCM how much air is flowing in, so it will register more MAF if there's been any flow increase. Since it knows the airflow, it can still provide the right a/f ratio.
TurboTR
I'm fully aware of the MAF, but not so much in detail about the functions it conducts.
I actually have a very interesting tuning article concerning our cars somewhere, I'm going to go find it and read it.
Here we go, this is the information in it about re-tuning for headers
Long tubes relocate the O2 sensors further downstream in the exhaust. This causes two issues. The first is, it will take the sensors longer to get hot enough to be in operating temperature range. This is because even self heating sensors rely somewhat on the heat from the gases to help heat them. The second problem is cause by the same thing as the first; the sensor is relocated down stream further. The computer knows the volume of air it has to push out of the cylinders for that air to reach the O2 sensor, so it knows that after it sprays fuel now, it can read it X amount of time later to see how accurate it was with it's predicted volume of fuel. By moving the O2 sensors further away from the motor, your increasing the volume of air between the cylinder and the sensor. Now the computer will be expecting to see a change in X time, but in fact, that change will be arriving at the sensor much later.
