ECM / PCM
2Goody
Usa
I bought a 06 GT - would not start
Codes were
B2103
P0600
P2105
I tried to get my ECM reflashed, the company that I sent it to, module experts, Said it was not reflash/repairable.
I ordered one of eBay. The code ends in YB like mine does. Once it arrives, could you tell me what I need to do? Can I program it myself?
I also bought a ECM from an 06 V6 but I don't dare to install it out of fear that it will mess something up
Thank you for the help!
rocknrod
Wake Forest, NC
B2103 Internal Transceiver PCM REFER to Section Antenna Damaged
P0600 - Serial Communication Link Description: Indicates an error occurred in the powertrain control module (PCM). This DTC may be set alone or in combination with P2105. Possible Damaged PCM - Go to Pinpoint Test QE.
P2105 - Throttle Actuator Control (TAC) System - Forced Engine Shutdown Description: The TAC system is in the failure mode effects management (FMEM) mode of forced engine shutdown. Diagnostic Aids: This DTC is an informational DTC and may be set in combination with a number of other DTCs which are causing the FMEM. Diagnose other DTCs first.
I couldn't find Test QE in my service manual, just suggestions to go there.
Ok,
Cannot use the v6 pcm in a gt.
The bare minimum you need to do is PATS to make the replacement pcm run.
VIN needs to be programmed.
May need axle ratio/tire size programmed if speedo is off.
You need IDS or Forscan and Vlinker USB adapter.
