I feel quite different. The ProKit I put on improved my ride. I have yet to hit a bumpstop, but maybe I'm just driving more carefully?? I would never expect a lowered car to get as good of a ride as stock, but in this case, its easy to see why its possible. The center coils of a Prokit are definitely softer than the straight rate of the stock spring and tigten up as you compress it. So, my low speed, small bumps are actually smoother now, but bigger bumps are a tighter. A good set of shocks are my next step, more than likely some Koni SA's. That will not exactly smooth the ride, but it will kill the "oscillation" of the spring...so there will be no flutter over bumps, just one solid bump.
I'd suggest those who are hitting the bump stops can go easy and cut the stops but a good shock is a smarter way to control the spring movement, and IMO, improve the ride...gives it that more buttoned down feel.
