(sp Woes)
Let me preface with I hate electrical gremlins like everyone else.
Latest issue has to do with power to the front turn signal assemblies.
The right side does not have power to the parking light (large bulb) (center post on the plug), but has power to the turn signal (same bulb) (side post on the plug). The side marker (small bulb) in the same front assembly works fine.
The left side parking light and turn signal works fine (large bulb). The side marker plug (small bulb) is not getting power.
I get having an issue with one thing, but both sides and different plugs? There's no fuses for these plugs that I can find aside from possibly the bussed electrical connector fuses 59,63,67, but everything else is working fine. Headlights/foglights work as well.
I replaced all four bulbs knowing it wouldn't help since there's no power going to the posts on the plugs. How do I backtrack this to the issue?
