Electrical Wows
86GT351
Sunny South Florida
You do not have to reprogram keys to swap out a SJB...
also the sockets for the bulb that you are having problems with are also known for problems... try swapping the drivers to the passenger side to see if that is where your problem is at.
THis is per Ford's Workshop manual
Tucson, AZ
Where the bulbs leds? I tried using leds for the license plate lights, and the circuit decided it didn't like them (would blink twice when arming alarm just like the normal bulbs, but would not illuminate when running lights were on). I put standard bulbs back in and they work fine now.
scramblr
New Braunfels, Texas
Problem is tracing the wires back to the source through the multiple harnesses. Followed the above schematics as best as possible, but impossible to trace unless you take the wires out of the harness.
I also think it may be the SJB since it's two different plugs. We'll see what the testing shows.
Sent from my SM-G986U using Tapatalk
scramblr
Nah, regular bulbs and swapped out for brand new ones.
You dont have to pull wires apart. Just need to figure out which wires in what SJB connector go to the bulbs that do not work. Than with the sjb removed, continuity test the two wires going to the non-working bulbs. The hard part is figuring out which SJB connector!
scramblr
I know, that's my point, short of pulling the wires apart, I don't know how to determine where they start and from which plug. Forscan tool comes in tomorrow so we'll see what that says.
scramblr
I decided to not kill brain cells on this for now, so I just spliced the two bulbs from the opposite sides of the car. Interestingly, I found the left side marker that isn't getting power (small plug), the ground wire is also not grounded. That gave me a headache for a few minutes trying to figure out why there was power (from the other side), but the bulb still would not turn on. So I had to ground the small plug and now everything works.
It is possible, that I may have caused this messing with the BEC. I replaced the center tray (inside the BEC) due to it melting from the cooling fan, but I think the SJB fuses are in the first tray, so who knows. Something I'll trouble shoot when it's not 100* in the garage...or the SJB craps out all together.
Why does water / moisture even getting into the SJB ?? Is there provisions for a drain ?
Some silica gel / desiccant would / should solve solve moisture ingress problems.
Joe combs
Northern Kentucky
Actually you do. It is a module and the vehicle needs to be trained that there is a new module in the car or all features will not work. Most times you need 2 keys also.
The keys are not linked to the SJB... i have swapped several in my garage and never had to had to have 2 keys. Key data is not maintained within the SJB. Yes it needs to be configured for the car, but the keys have nothing to do with the SJB configuration.
Keys/PATS are not affected by SJB swap.
What needs to be programmed to/in SJB are vehicle specific options like:TPMS, keyfobs, fog lamps, rolling door locks, etc. None of that will keep the vehicle from being driven.
scramblr
From what I have seen, it leaks to the top of the box and trickles down into where the harness' plug into the SJB. Then causes corrosion at the pins coming out of the SJB. Once that happens, the SJB loses it's mind. This guys has a decent video replacing it and at 7:20 shows the corrosion on the pins.
86GT351
Sunny South Florida
OK. I guess the Work Shop Manual is wrong then?
Wouldnt be the first time! I worked as a dealer tech for 15 years.
I have become quite familiar with the SJB with this swap and wanting to add features I did not have (rolling door locks and oem fog lamps)
1 Ford told me rolling door locks will not work on mine, they do.
2 Ford told me they can enable fog lights, this was not correct. Even enabled, they still didnt work. I had to add jumper to bypass the SJB.
So yea, I take info in shop manuals with a grain of salt. I lost track of how many times the diagnostic steps did not help me find an electrical issue.
86GT351
Sunny South Florida
I get that. However basics like programming are not something they would be wrong about.
My SJB was in "factory mode, configuration incomplete" when I first connected to mine. All factory options were working. To me that means at some point, something was done to mine and the programmimg was incomplete. Yet everything worked.
Lime1Gt
According to my wiring diagram, if correct for your model year, Power to feed the problem lights comes from the SJB as you already know. If you were to remove connector C2280D from SJB and supply power to pin 16 Wht/Rd wire of the connector it should light the LS Marker. Supplying power to pin 31 Blk/Pnk of the same connector should light the Rt Park lamp. If they light the problem should be in the SJB. If they don't the circuits also run through the BEC on route to the lights. It's been awhile but I think the C2280D is the one closest to the floor on the back side of the SJB.
Indecently, I had an issue when I had my 05 where I had added a brake/park sockets to the inner park rear lights so as to have all lights lit with brakes On. I just tied the brake wiring into the second bulb socket on each side. It lasted quite a while until one day I was in heavy stop and go traffic on a hot day. Those two brake lights went dead but bulbs were good. I ended up getting an electrician friend of mine to check the SJB board and he found a defective part that couldn't handle the load of the extra bulb on that circuit. He replaced the part, I think a transistor or i/c and I change the wiring back to factory.
JEWC_Motorsports
S197 Junkie
Texas
I was always under the impression the key data was stored in the gauge cluster.
