Deathstang II
The EPAS rack will not bolt into a 05-10 Mustang. You have to use the 11 and newer crossmember. Not sure if you are aware of that.
The EPAS will fit on an 05-09 Subframe, however, a small section of the frame needs to be cut to fit the rack properly. Instead of dealing with all that, I just went ahead and put a BMR K-Member on paired up with a '13 EPAS.
@Deathstang II Im with you there... I am looking into doing this mod as well but cannot justify speading $330 USD on a freaking harness. Thats nuts. Need to figure out how to use the OEM one.
I ended up just purchasing the harness unfortunately...Casey makes a solid harness, after purchasing it I will agree it was seamlessly plug and play, no modifying a stock harness to make it function. And If I had any questions he was more than willing to allow me to hit 'em up.
I used the f150 harness and installed one of these on my 05 with a BMR K member, I also didn't use the third mounting hole.
I used the third mounting hole because....well, if its there may as well use it for extra rigidity. That and BMR supplies you with the hardware for the third hole, so why not.
