Front brake hose 2008 vs 2010 ....
GriffX
Rural Germany
Manual? The Ford manual says something below the filler level. 12,7 mm below hole
Don't know how much is inside, something above 3 l.
The rear diff must be filled up.
PS, the original drain plug has just an O-ring as seal, should be changed each time, I guess that was the reason for the silicone?
PS2 the diff without the cooling cover has some problems with heat on the Autobahn. When I changed it, the oil had a burned smell.
brasil
Germany
..the reason for the silicone was a stripped darin plug... but fortunately the tread in the oil pan was o.k.
for the tranny I will go with the 12.5mm lower than the filler hole.. ( Mercon V )
and for the axle... fully filled. ( 75 w 140 Amsoil severe duty and a bottle of ford friction modifier )
For the engine I used Shell Helix Ultra A3/B4 5w30...
brasil
Germany
@ rocknrod... below the filler hole - you are talking about the transmission ? I filled up the fluid , until the level reached 12.5mm ( 1/2 " ) below the filler hole.
@ JC SSP. .. my car has a manual transmission (TR 3650 ). but the Video you posted is very informative .
