obxdude018
FRPP Manifold, 39lbs. injectors, C&L Racer 95mm, Comp Cams NSR 127200
Up for sale is the FRPP Manifold Gen 1, it is used, still in great shape, I used for roughly 8k but bought it used from another member, fuel rail goes with it. Also, gt500 tb with adapter, throttle body was new when I bought it, its complete comes with bbr adapter. Throttle body holes have been drilled bigger to accomodate adapter. Also comes with the intake adapter. Also crossover tube, it's used, not really anything else to list about it, I will remove hoses once I want to start with messing with car parts again. Also have FRPP 39lb injectors, they are used and came with the motor when I did the v8 swap. Finally is the C&L Racer 95mm intake it doesn't have silicone adapter as I received it in a package deal with the bbr adapter. Has a few bent fins, but doesnt affect operation. Comp Cams NSR 127200, they were used in my car for 8k, bought from another member on here. I received them with a small nick in the one lobe, however it doesn't contact the follower. Also have a set of Steeda underdrive pulleys, used came with the engine when I did the swap, has some wear and tear, but that is just superficial. Taking OBO now. Would like to get this stuff moved.
Manifold - Sold
GT500 TB - Sold
Crossover tube - Sold
39lbs injectors - Sold
C&L Racer - Sold
Comp Cams - $375 shipped
Steeda UDP - Sold
Manifold - Sold
GT500 TB - Sold
C&L Racer - Sold
Steeda UDP - Sold
