Looking to upgrade your wiring from the fpdm to the fuel hat to lower duty cycle even more and get more out of fuel system? Then this harness is for you. Quick and easy to install harness that runs 10 gauge power and ground wire from the Fpdm in the trunk to the the top of the fuel hat. Keeps your stock harness intact you merely run the new harness along the exsisting harness, comes with zipties and heat shrink for a clean install.
Harness is $15 shipped in the cont us to forum members or just $10 more when you buy the fuel system wire upgrade kit or one of my fuel systems.
And again I can build custom setups or even a dual harness for guys with dual pump/dual fpdm setups, so pm me with your needs.
Big thanks to Jason for doing some before and after datalogging of this harness for me. His system is 340lph pump with the wire upgrade off the battery and bap. His average duty cycle dropped across the entire rpm range with this harness installed.
The top two black trend lines are from before and the bottom two trend lines are from after the harness install.
Runs were done in the same location and same gear each time.
