StockishS197
Been chasing some intermittent P0300 and P0316 for a while now with Lito on my 07 GT. Car has a Steeda CAI, LTs, CMDPs, hot rod cams and FRPP 27lb injectors.
In combing through my data logs and watching real time, I noticed my FPDC at idle is around .20-.25, and at WOT near 6800 RPM, .48-.50 FPDC. Does that indicate that the pump is at/near 100% duty cycle? Is that typical for a bolt on cammed car?
Looking at fuel pressure drop across the injectors, at WOT it holds fairly steady at 40PSI, but on throttle tip in it may drop to low 30s or in some cases lower than 30 PSI, but generally fluctuates between 37-41 PSI.
Fuel filter is new, so I am wondering if the FP sock might be clogged?
