LegendLives
What are things you can do to provide the traction/bite you need for take-off. I know slicks but besides that are there other things you can do to plant the tires? i.e. bolt on's?
Also if you had no access to any slicks what could you do at the track? lower tire pressure? really heat the radials? I ask because in the spring I would like to make a couple of passes at the strip to see what the old girl will do and also because when Im just cruising around and I want to nail it I hate that it goes right up in smoke...
