That definitely does help. Was wondering if the frps had a connection with the system. I'll replace the harness relay and then the frps. I don't think it has to do with anything hat or pump related. Correct me if I'm wrong, but it should still run even with a leak or clog correct? I verified the old pump to work, then I hooked it to the fuel pump harness, turned on power but nothing happened.
Also, if it is the frps then why is it when I plugged the original wire harness to the FPDM I read the 12v I need from the old fuel pump plug.
It could run or not depending on how bad the leak or clog is. I developed a leak from a tear about as wide as a dime and hair thin on my hat and my car held no pressure and wouldn't run.
But I can hear the pump running and priming the whole time.
Don't get too hung up on the voltage difference from the oem setup to the gt500 it uses a second fpdm that mimics the first and shares the load between the to pumps to get the same result the car wants so readings will be different.
I would still positively half split the problem a few times. By doing mechanical checks first. Physically make sure you can get fuel through the pumps to the rails.
I would get some wire and run 12v from the battery and a wire to chassis ground straight to the prongs on the plug at the fuel hat to each pump and make sure it moves fuel and creates pressure at the rails. if the pump kicks right on you should have 40psi plus in seconds if everything is good in the hat, line and filter. If you do, you now know the hat plumbing, pumps, line and rails and your fuel pressure gauge is good.
If your not getting anything at the rails and you just bypassed all the oem wiring and controls you have a leak/clog.
Depending on the result from this test you now know 100% where to focus on. Either looking for the physically problem or jumping into the electrical side, ie frps, relays, fuses, wire runs for the harness, inline fuse. Look for damaged/frayed wires, burnt contacts on fuse receptacles etc.
