DVEST8R
- Joined
- Jul 8, 2012
- Posts
- 850
- Reaction score
- 1
yea the only thing that bothers me is that I feel this set up is almost tapped out.....may have a 6.8x in it we will see thoLove it! Makes me want to mess with my 3V.
Thanks Neal.....would not have been possible with out ur help and Kelly (BMR tech)'s help.Man i just saw your thread! That's awesome!!!
Possible fuel? What fuel pump or pumps you running? BAP or pump size please!I did have problems this weekend tho...every pass in 4th gear the car would surge on the nitrous. Think I may have either a nitrous issue or a converter issue
Thanks !Car looks good leaving.
good luck and keep us posted sir !Gonna revive this thread,
I'm gonna attempt this record as well come tomorrow.
Set up:
Engine: Detroit Rockers N/A, CMDP, UDP, JLT 3
Exhaust: JBA LT, O/R H, Ford stingers (might rip these off and go open headers just for the hell of it)
Drivetrain: 4.10's, stock clutch and driveshaft
Tires MT E/T Streets 275/60/15
Nitrous: Zex wet kit, .67 jet.
Fuel is going to be 100 oct.
I don't know what my previous set up will do, last time I did a pull on the strip I was at 7500k DA, I've moved since then and the DA here is around 3050.
Suspension set up is new too as well as the tire never used a drag radial for my previous times so wish me luck boys!![]()
sorry to hear about your luck......come back strongerSorry guys couldn't do it, best i went was a 11.9
4th gear blew up towards the end of the track, stock clutch couldn't take it.
all I have local is 1/8 mile tracks, the car that went 10.8x in the 1/4 for the record went 6.86 in the 1/8.the record is 10.8x on nitrous ? or am i missing something here
unsure who you are refrencing but I will answer any way, I have solid lowers and dbl adj upper, stock struts/ shocks, and run mine on 14.5 psi in the tiresWhat are you running your tire pressures at? Also, is the suspension you have adjustable?
