I saw that. When you have the Diff installed, have the tubes welded!!!
That's the plan. May do a gear change as well. Not sure yet.
To me and on the video it doesnt look or sound like your loading the converter at all or flashing the TC, but a slow roll out. Foot brake the hell out of it, make them spool, load the converter and go!! apples to oranges to our setups, but your car should have a letter better 60' even with that gear. JMO.I am thinking about going back to 3.73's myself, or upping the stall on the converter. I went to the 3.27 because lots of people said it would load the turbos better. Well it does load them better but I can't get it going to start. My 60's are in the 1.90-2.10 range and it doesn't' really spool and start pulling until about 50 feet out. When I initially changed I ran, on 10# boost setting, 11.78 on the 3.27's. That's the same I ran on the 3.73's, just had a slower 60 with the 3.27's. At the higher HP and boost levels I am running now I think it would be a lot faster with the 3.73's.
I think 4.10 may be a little much for a turbo setup, the 3.73's should be a better option, even with your manual trans.
Earl
great news Brady and Earl. Things are moving direction for everyone. Brady, does the new trans feel better. pros cons??
Earl, how is your car coming?
How are you liking the new trans setup, now that you have some miles on the combination?
Earl
