Help moding the Whipple setup
itonano
Hello guys, is my first post here around, im from Spain, so dont be too demanding because my english, i will explain as better as i can :D
First of all, I own a black GT/CS from 2007, a bit modded but nothing special...till now.
1.¿Whats at the garage?
-Whipple black/blue 2.3 Supercharger with the HO setup
-Maf 95 with the SC
-Whipple stock Intake and all the SC stuff
2.¿What did I buy to complete the setup?
Here is where i want opinions and whatever u wanna say.
-GT500 fuel pump and all the wiring and stuff
-Whipple 3.25 pulley and belt
-Idler 100mm pulley needed????
-Autometer digital air/fuel wideband
-AFCO heat exchanger
-Mishimoto radiator
-Autolite spark plugs
-FRPP 62mm throttle body
-Roush 48lbs injectors from my friend santi!!
3.¿What's the limit I shoul go with stock engine?
-I wanna end the setup going with the Kooks and X as i got them half price
Should I put them to better adjust the setup?
-Didnt see anywhere a JLT specific CAI for the Whipple SC...
Will my JLT 110mm cone filter with the Whipple tube work together?
-What's the limit of HP i should go being stock?
-48 injectors will fit with the Whipple?
-is the idler pulley needed?
All this will complete with a custom tune from Lito, i've been advised from lito and my friend Santi, but would like to know your opinions also.
How u see the project?? Would like in long time get it stroked.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
If Lito has advised you then definitely go with that! He'll also advise and give you a safe tune for your build.
skwerl
tree hugger
central Florida
I am going to disagree with the Mishimoto radiator. I think the stock radiator and fan shroud will work better than most any aftermarket setup. The only time I have seen people with cooling problems is when they use an aftermarket radiator or fan. The stock setup works very well.
itonano
Hmm thanks for that skwerl
How many rwhp do you think guys i will run?
