Huck
I installed Detroit Rocker cams this week and the install went well. When I test drove the car I noticed the sound that a strong wind makes as it blows over your house. Kind of like a howling wind. The sound is isolated to the driver’s side (not sure it matters but I also replaced the valve covers). The sound got louder as the rpm’s increased. I removed the valve cover tonight and check all the cam followers. All are in place and there are no scratches on the cams. I then removed the caps and inspected each one. There were slight groves in a couple of the caps noticeable when I ran my fingernail over the surface. I can't say if these were there with the stock cams. I don’t notice any marks on the cams themselves.
I re-torqued the caps and the sound is still there. You can hear the sound in the attached video. It is a higher frequency sound then the engine idle. It’s short because I didn’t want to run the engine very long. Also, the smoke is from oil that soaked through a towel onto the exhaust manifold.
I am at a complete loss of that could be causing this sound. Any help would be greatly appreciated.
![](/proxy.php?image=http%3A%2F%2Fi1098.photobucket.com%2Falbums%2Fg363%2Fhuckohio%2Fth_VIDEO0005-2.jpg&hash=2c708e54931eb9f5ace6a4ae3aaf189f)
