HOLYWD's build 20**
Redfire_WNL
THE BEAST UNLEASHED!
TAMPA, FL
LOL I figured you would be a little quicker. Glad you got it figured out though and it sounds nice with open pipes.
HOLYWD
S197 Junkie
Thanks man , but I cut her off and came inside , started smoking quite a bit of white smoke from the headers / under the motor . Any ideas ? new fluids ? leftover gasket residue ? should I check all the pulleys , could pulleys not bolted down/ seated correctly cause that ? was idling a little rough after 2 min .... should i check the tune ?
maybe wire the A/f gauge before I try again ?
Redfire_WNL
TAMPA, FL
If it has been awhile it will run rough for a bit then eventually it should even out but who tuned for your black lung? It could possibly be unburnt fuel making it smoke from when you changed the manifold. Did you calibrate it after you install the manifold? (turn the key 4 times to the on position with out turning the engine)
Redfire_WNL
TAMPA, FL
To get the Fuel pressurized in the fuel rails I guess but thats what I was told to do when I installed mine.
HOLYWD
S197 Junkie
2010 spring build
First time out doors in almost 3 months
Dirty an still sexy
HAWTTTT!!!!
Sexy
Out in the light
Look how dirty the car is
1st attempt
Wasn't working
The Trifecta!!
Snake
I loveeeee my stance
Beautiful !
HOLYWD
S197 Junkie
2010 spring build
K well there will be another attempt shortly ...
Blxcklist
Hi Im Justin
Idaho
Looks fucking bad ass bro! I bet you were stoked when that fucker fired up!
HOLYWD
S197 Junkie
ya , about to drive it for the first time maybe , still hasnt moved , white smoke scared me = /
I am guessing i need to let it run for a bit and clear off any residue
