Hot Rod cams/transmission codes.
Jambarino
Fountain Inn,SC
Alright had hot rod cams installed on my 06 automatic and got a remote tune.Yesterday when driving around my neighborhood my over drive light started flashing . Read the codes and its p0745, p0732, p0733, the first is a solenoid, the others are incorrect ratio?My tuner says the transmission detected a slip and its not the tune, its never thrown codes until the tune was put on.
Car has 70k miles, tranny fluid changed at 30k and 62k miles, never been raced and I rarely get on it, only occasionally.When driving it shifts smooth and firmly, revs do not jump and I haven't felt it slip.Any ideas? Is it tune related and what could be the fix?
Jambarino
Fountain Inn,SC
Unfortunately its not the tune.Tranny is slipping on the 2-3 shift,bounces back and forth between 3rd and 2nd when going through a parking lot ran a datalog on the tranny and its definitely slipping :(
Ssiptang
Downers Grove, IL
Sorry its tune related. OD flashing and tranny issues with hotrod cams was a known issue which big tuners already have a fix for.
808muscle
Maui
Its the tune. Even if your trans is slipping most likely its the tune thats causing that. My first cam tune was so far off the car didnt want to go into first. Had to manually shift it. All good auto tuners know this fix.
