Cookiemonster
the purists would hate you, but I think it sounds for a fun car. is there any way you could make that street legal at all?
I put down 341hp and 310 tq with thumper cams,mac lts,steeda pulleys,c&l racer intake, frpp intake, gt500 TB, 3.73's and 3k converter with 93 octane tune
Sent from my ADR6300 using Tapatalk
A LSx motor would get you a n/a 400whp easily with just bolt ons and its a much smaller package but with equivalent weight (450 lbs) to the modular motor. I know .. ford forum and all but... The smaller 5.3l vortec can be purchased for under $1000, LS1 (5.7l) is about $1000, LS2 (6.0l) is about $2000. These motors a are all fairly interchangeable when it comes to heads, cam, plenum etc and even the smaller vortec motors can make good power. Only downside would be you would have to run custom gauges and a standalone ecu. You would probably want to run the t56 transmission (ls1 transmission). Off the cuff I'd guess the swap would be about $2k to get the engine the way you want, $500 for transmission, another $3k for mounts, cross member, ecu, gauges, misc stuff. Discount that by $1500 if you sell your stock 4.6 and tr3650 transmission.
Menes, curious what your plan is with the Cali emissions.
Im kind of in the same boat as you. Want to maximize my NA potential without touching crank.
If your looking to go all out in maximizing NA hp, you would def want long tubes + cams + heads
im looking into getting BBR stage 1s.
sounds about right I had 342/322 with comparable mods (nsr cam, mac lts, o/r prochamber, jlt cai, cmdp, gt500 tb, steeda udp, 4.10s, 93 tune, eH2O pump)I put down 341hp and 310 tq with thumper cams,mac lts,steeda pulleys,c&l racer intake, frpp intake, gt500 TB, 3.73's and 3k converter with 93 octane tune
Wish I had the tq you had! I hate how mine is so low.
It's your FRPP intake manifold that kills your torque. I had the FRPP intake manifold and swapped it for delete plates and lost a little HP but gained torque.
Other than a tune and a larger throttle body, there isn't much left to do to add NA power that doesn't involve opening up the engine. What's the most I'd get form a tune and larger throttle body? Maybe 10 HP?
Sell your car and get a 5.0--Better handling for racing and you're already at your power goal from the start.
If you haven't tuned for those cams, I suspect you'd get more than just 10hp. Maybe not though?
You could also go with a considerably more aggressive cam.
The NSR stage 2's are mild but they really are good for about 35 wheel (my tuner tested it out on mine, I actually have the original dyno sheet somewhere)If you haven't tuned for those cams, I suspect you'd get more than just 10hp. Maybe not though?
