How Much Does It Weigh?
kings2006
if you have stock cams and valves then your fine but if you have aftermarket cams you will need a tune.
J
JP229
Guest
Yuasa Battery "ytx20l-bs" and some trimming of the battery tray is what I did since i didnt want to relocate the battery.
The battery I had in the car weighed 31lbs, the yuasa weighs 15lbs. The battery is pretty dependable considering the one I have, came back from the dead out of a Rhino of some sort. There is also a slightly bigger one(17lbs) with more cold crank amps that will fit sideways in the battery tray
Also was able to turn the battery and trim the tray to help extract a little heat and clean up the engine bay some. Makes it a little easier to get to headers if you need to for any reason. Here are a couple pics.
TheJimmy
can you post more pictures of the modified battery tray i am interested in how you made that work and possibly doing it myself this summer
All he did was cut it in half, turned the battery side ways moved the post over to secure the strap, im sure drilled a hole for that. And the box still mounts to the car using the factory bolts looks like. Great job i must say!
J
JP229
Guest
YUP! But thanks.
Also drilled two holes in the car underneath where the strap screws down so the screws can tighten.
I will take it out tonight and get a couple more pics and post a thread in Tech so I dont clutter this one up more. lol
Columbus, GA
Pture please
I want to take off the stock axle tube weights, but can not locate them. I have looked under the car, but have found nothing. If anyone has a picture of what I am looking for I would be most grateful. I must be overlooking it as I bought this car bone stock.
I am new here and I ran a search on this thread, found what I was looking for, but it has been edited and the picture is no longer attached to the post on this thread.
TheJimmy
some cars have the weights some do not so if you dont see them they probably arent there
