1000 whp? On corn, not with 1000cc IMHO
I've been told my 120s would be pushing it. 120lb injectors should equal 1260cc or so.1000 whp? On corn, not with 1000cc IMHO
Beef, Was this with the JPC Triple Hat and 3-465s ? Im hoping to crack 1000rwhp safely with ID1000s. T1(Makers of ID injectors told me no way) with Walboro pumps, it would be marginal with twin Weldon 2015 pumps and I would need a base pressure of 110psi.
What are your thoughts on my setup? I'm running 48psi base fuel pressure with Bosch 120s. I'm at high altitude, so I'm sure my corrected numbers with be fine. But I'd also like to go to the next Mustang Collective "Buckeye Brawl", which is guaranteed to be closer to sea level than I am now.Yea, those 255s won't support the flow at the pressure you would need to make 1000rwhp with ID1000s. Electric pumps typically lose flow output significantly with an increase in output pressure.
Are you running 14psi of boost at the e85 number in your sig?What are your thoughts on my setup? I'm running 48psi base fuel pressure with Bosch 120s. I'm at high altitude, so I'm sure my corrected numbers with be fine. But I'd also like to go to the next Mustang Collective "Buckeye Brawl", which is guaranteed to be closer to sea level than I am now.
**EDIT**
Also running triple Walbro 255s in a Fore hat. -10AN supply, -8AN return.
Sent from my Galaxy Nexus using Tapatalk 2
But isn't it the 465s everyone's having problems with?2 465's will get you there,
i run 3 for the added safety margin, i have the jpc hat, might as well run the pumps
Yeah, the 802 run was at 14psi. The next run will be at this 17psi setting, then 20psi... if all looks well. You can bet we'll be paying careful attention to fuel pressure and fuel injector duty cycles.Are you running 14psi of boost at the e85 number in your sig?
Damn. I really don't want to have to buy new pumps, but I guess there are more expensive things out there...I think you would be pushing it. I'd do 340lph pumps so you don't run the pumps at their max.
Thanks. I'm on my phone now, but I'll definitely check them out later.Here is a good set of fuel calculators that are pretty accurate:
http://www.mopacautosupply.com/fuelcalculators/fuelcalculators.htm
I love it. It wasn't to terribly difficult to install. The hardest part was getting the three -6AN lines to hat. It's quite a tight fit.How do you like the return setup and how difficult was it to install?
Why aren't you going with better injectors and less base pressure?Thanks, I am upgrading to Triple 465s. I spoke to T1(Injector Dynamics) and they told me it was going to require a crazy high base pressure and be close, we shall see.
70 psi base pressure, seems high, but if that's how Lund tuned it I'd defer to him
I made 56 HP per 440cc injector on my boosted Honda on E85, with plenty of headroom. Extrapolating that, eight 1000cc injectors should be good for ~1000HP, again, with plenty of headroom.
EDIT - That was with the regulator at a base pressure of 38 psi. 10 psi boost = 48 psi of fuel pressure once it ramped. Used a single Walbro 255.
So the question is how far have you been able to go with E85 and 1000cc injectors?
What's with all the guesswork up in here? You can calculate this shit.
8 1000cc injectors at 80% duty cycle, assuming a BSFC of 0.9 (that's some added headroom for those that like to run rich), flow enough to support 690 HP by my calculations.
Now before you go telling me "I made 715 HP hurt durr", that calculation is conservative. I don't believe in running injectors above 80% duty cycle.
They look nice.Injectors came today.
I know your pain. Sucks to think I may go to the dyno tomorrow and still have some issues with spark, as I haven't really been able to test much past 14psi on the street.The car has too much power for any kind of meaningful wot pull.
Same with mine. I hated all the adapters at first (two height adapters for each... one on top and bottom, as well as the USCAR adapter), but all seems well. Other than an initial leaking o-ring and the USCAR adapters feeling flimsy, they seem to be doing a great job.They have a few adapters, lol. USCAR electrical adapters and a height adapter.
