Fairly simple, really. 450hp super easy, super cheap.
Start with this kit, which is incredible looking. http://cgi.ebay.com/ebaymotors/_W0Q...3QQsspagenameZSTRKQ3aMEWAXQ3aIT#ht_2030wt_734
From what I can tell, it comes with everything and more. Coolant tank relocation, option to vent wastegate to atm or to exhaust, metal rad hoses, it even hooks up right after your cats, then goes back to where it left off in the system.
Pretty darn complete for around $1300, and boost brothers produce amazing stuff.
The remaining components are injector upgrade, fuel system upgrade, and spark plug upgrade.
Spark plug:
HT0's are $80 from summit (2005-2008.5)
Brisk silvers are $130 on ebay (2009-2010)
Injectors needed are 39lb. More than that is overkill.
$270 on ebay
Around $100 on this forum
The only fuel system upgrade you REALLY need, is upgrading the stock pump and FPDM. The FPDM upgrade is easy, splitting a relay into the white wire on the FPDM. The pump upgrade is part of Lightblades creation, adding an aeromotive stealth 340 in place of the stock pump, that can be found on ebay for about $170
So adding all of that up, you can average about $1700 for the components, then fork out about $300 for tuning. That's it. 450hp for $2000.
I hope this is tech enough. Enjoy guys.
Spark plug:
$270 on ebay
