idle vacuum
2010Elanore
Honolulu, HI
In my Sig are my mods, only getting around -6 or -7 pressure at idle. Is this normal with a lope cam? Checked for leaks, nothing I could see.
Thats way low for nsr cams. what compression on the motor?
Do you mean -6 or 7 in/hg vaccum right?
2010Elanore
Honolulu, HI
Just the stock motor, it is really weird. It has been checked for leaks 3 times with no luck. I wish I knew what the hell was going on. What else could play a role in the vacuum at idle? I am getting -10 or -11 on decel.
Also, yes i meant in/hg. Sorry about that.
stang67gt
wrench turner
Chicago
what gauge are you using? sounds more like negative psi rather than in. Hg, as 1 psi is roughly 2.03 in Hg. so your negative 6-7 would be 13-14" vacuum and 22" on decel.
My car with turbo, cams, and 9:1 compression sees 17-18 in/hg at idle but i still see the full 22-23 in/hg at decel.
May be your gauge, im not a fan of digital/electrical boost/vac gauges.
Is it hard to brake?
So it didnt use to read this low, and your brakes are fine?
Then its the gauge or the sender.
bullitt boy
NJ
Want to see an idle vacuum come to my house the wife hasn't touched it for months.
