If you Drag Race, PLEASE weld your axle tubes.
skwerl
tree hugger
central Florida
I would just say again...remember the radiator brace. You guys way under-estimated demand. BMR has a good rep and customers tend to run the same brand stuff on their car.
I'm not even sure it would help, but I would buy a BMR axle brace. Especially if it were visible from the driver's seat of the car behind me at the traffic light.
TurboFocus
Awesome, please do post the pics.
You're a good guy to have around here Jim.
Now get to working on that turbo kit, you're going to need two big ones for the ST SWPR. :asshat:
thanks buddy waiting on some nickel rod to come in. And we will see what it takes to put you out of commission :)
Curious because I've spent the majority of my career in power plant piping stress analysis - did he happen to inspect piping welds?
Back on topic - is any preheat required/recommended? Compared to the axle tubes, the pumpkin is a pretty big heat sink.
Norm
Ill ask him about what all he use to inspect. You definately have to preheat both the pumpkin and tubes to make sure you get good penetration.
WTF did you have done to your damn focus! 600whp! holy crap!
lol built motor, stock block, ported head, and cams, 29psi on a GT3582r turbo. :)
He had a built motor/turbo combo.
He is one of the better fabricators in this area, and knows how to make some really ice turbo kits, that make some power.
We had a local fox body car that was going like low low 9's with a T56 and a Turbo kit from TurboFocus...with a 347 budget engine.
Thanks again for the compliment. Bens car at 14psi went 9.20 at 151mph on pump gas, he could drive the F out of that car.
AJCrader
Glendale, AZ
Just got a quote from the most reputable differential shop here of $170 to bring the car in and have them remove the axle and then weld the tubes...now I just need $170...also going to try to get the axle brace too
sharkbaits
Can anyone recommend a shop in the DC/Maryland area to have this done at? I don't really drag race much, but I run the piss out of my car at AutoX and road courses, and I'd rather be safe than sorry.
Could Evo Performance or JPC do this?
We can do it. Just give us a call
410 729 0005
djniknala
Anyone know a good shop in Central Texas(Ft Hood area) to weld up the axle tubes?
Sent from my iPad using Tapatalk HD
Seer
Seems this is happening more with the 2011+. How often has this happened to a 05-09?
It happens in those cars once they start cutting good 60's and putting down power in the 400s.
Fact is the 2011+'s just get into that range a lot easier.
It's more of a 60' time thing and a power : weight thing.
Bmr4life
2005 GT
Atlanta
Anyone have their tubes welded around Atlanta. Seems like there is a very specific way the welding needs to be handled. If not, I'll order a CHE brace.
timfoster405
Maryland
Does this problem tend to relate to guys w/ manual transmissions?
I have two... both autos and have raced both of them w/ automatics.
On my 07 GT, I have never experience wheel hop yet. I have only raced my '13 once on stock tires... and the launch was smooth as ice...
scramblr
New Braunfels, Texas
There are plenty of 05-09s out there pushing well over 400 and at least in the few forums I frequent I haven't ran across this problem much, just a few times. Are the axle tubes in the 11+ different?
Bmr4life
2005 GT
Atlanta
The rear ends are the same. I'm positive its due to fact that ALL 5.0s are making over 400hp versus just a handful of 4.6s, relatively speaking.
Sent from my ADR6425LVW using Tapatalk 2
Ssiptang
Downers Grove, IL
I shopped around.
They either have no clue what im talking about or quoted me rediculous amount of money to have my rear end pulled.
timfoster405
Maryland
Bump...
Bmr4life
2005 GT
Atlanta
I contacted the guy that installed my gears on my last. Says he's done it several times and would charge 100. His shop is in Covington
Yagermeister
DFW
Do you have to take the diff cover off, drain the fluid, then weld or can you weld the tubes and be on your way?
Sent from my Galaxy Nexus using Tapatalk 2
